If you have a 650 front, did you get specific 650 forks or did you cut em down too.
It will be great to see the next ride, though i wouldn’t be confident with the front bent/straightened forks. Sorry i value my teeth.
it was easier than i thought it would be, the hardest part was getting them aligned with each other and the bottom bracket… we used two axels to get them parallel and to hold them in place and then adjusted them to be in line with the bottom bracket…
Haven’t ridden the bike yet, (still not finished) but I’d would say that there wont be any movement back there…i have a picture of them after we welded them somewhere… just not sure where…
oh, we also shortened the stays as well so the wheel can sit right up against the seat tube.
This is the first time we’ve tried something like this so this is just a test frame…Would love to build my own track frame from scratch one day…
As for the 650c forks, no they are proper 650c forks…They, and the wheelset are off an old pursuit frame my dad used to own… no idea what happened to it though… those are the only things left of it now…
