My XT PD-M780 pedals have developed play in the bearings so I’d like to know if anyone here has successfully pulled them apart and adjusted the bearings? Taking the axle off the pedal is easy, the hard part is adjusting the bearings themselves as I understand you may require the TL-PD63 tool. Anyone here done it with/without the special tool?
Thanks,
I found this on the Park tool website which is helpful:
The bearings may be adjusted. Some models require a 7mm wrench for the locknut and a 10mm wrench for the adjusting cone. However, some models have the locknut recessed and require a tool from Shimano®, the TL- PD-63. This is double socket tool holds the adjusting cone and loosens the locknut. The inner socket of the PD-63 is double sided, one is a 7mm, the other is 8mm, and this is used to secure or loosen the locknut. The outer portion is also double sided, with a 10mm and 11mm option, and it is used to move the cone.
The Shimano TL-PD-73 tool
The threads of the adjusting cone and locknut are right hand-threaded on both left and right pedals. Hold shaft unit secure by holding pedal thread in soft jaws of a vise. Use the Park Tool AV-4 axle vise for this. If you don’t have a vise, re-mount pedal in crank to hold it secure.
To test bearing adjustment, grab cylinder section of shaft unit, not plastic section. Bearing adjustment only effects cylinder section. Play in plastic section will disappear when unit is remounted in pedal body. To adjust, hold cone with 10mm wrench CBW-1 and loosen counter-clockwise locknut with 7mm wrench.
You know what this is a lesson in- buy cheap, buy twice.
I’ve also got 2 sets of XTR PD-M980 and they have seen much more use, but the bearings are buttery smooth still. Lesson, but XTR and Dura Ace.
My first pair of 980’s actually had quite a bit of movement after only roughly 1000k (on road) and needed to be rebuilt hence buying the expensive and never again used TL-PD63 tool.
The pedals were used on a fixed gear MTB (brakeless) and it’s possible that the force on the pedals may have caused some possible problems although it would seem unlikely considering the pedals were designed for professional cross country MTB racing.
Just serviced your old pedals.
Adjusted the little cup/cones with a 10mm and a small adjustable spanner, and used a 17mm and a big adjustable spanner to get the axles out, then packed with fresh grease which forces the old stuff out when you screw the axles back in.
