I need help…
I’ve just finished my single speed project and the frame is slightly smaller than I’m used to. This shouldn’t be too much of a problem as long as I can replicate the body position I’m used to from my road bike. What is the easiest way to measure an existing position (saddle, handlebars, offsets etc)?
Something not too technical would be great.
Distance of horizontal line from saddle to handlebar
Distance from top of saddle to centre of BB
Amount of drop or rise of handlebar relative to horizontal line from saddle
If these measurements are the same as your road bike, you should be OK unless you have to compromise something like a really short/long stem which will affect handling.
Probably, although I usually just use the same measurement and adjust according to feel after a few rides. Bare in mind that using different saddles will affect your saddle height too.
a bit tricky first time but drop a plumb line (a bit of string with a heavy washer or something tied to the end will do) to the centre of your bb and measure level back to the tip of your saddle. You might need to adjust fore & aft a bit for comfort if your saddle is different to the one on the bike you took the measurement from (and if the frame is a lot smaller you might need to consider a seatpost swap)
I have found that when back ache occurs, it is usually the result of stem length and handlebar height. If the frame is on the small size a longer stem might help with a higher ‘degree’ rise might do the trick.
Yes that sounds like an accurate synopsis of my situation. I think I’ll increase the stem from 100 to 110 or 120mm and get my ‘rise’ happening. Is 120mm dicky looking on a 55cm frame? I’d rather be in pain than look dicky after all…
If you have a sore back it may be partly due to the bike not fitting and partly due to you. How strong is your core (deep transverse abdominals)? These muscles are the ones that support your lower back. I don’t mean the six pack, but the ones underneath. If you haven’t been training them, it could be your problem. Classes in mat pilates and yoga are good, or get a fitball and start a program.
