Mini pumps
Yeah the Blackburn seems to do the trick, only prob is the tyre lever on it isnt the best. but it has alen keys, a flat blade screw driver, chain break, hex key most of the stuff you need. Just purchased pedros trixie tool so that should do me for anything malfunctions on the road.
The trixie is pretty good, I think it is well worth the money
I’m gonna have to get more pedros tools, they come with a lifetime warranty
I like the genuine innovations “second-wind”, comes in 2 sizes, i’ve got the small one. Works both as a regular pump and a CO2 pump. Does the trick, small enough for a back pocket.
Topeak Pocket Rocket. They’re light, small, and go up to 160PSI. They don’t take too long to pump either, highly recommended!
that depends on what you call ‘don’t take too long’
i have a road morph and that push comes to shove takes too long…
True that…but then again I don’t use it that much, I’ve got Stan’s NoTubes to thank for that!
got an old topeak master blaster, it’s been going strong for 14 years now… Live in my bag beside the kryptonite mini U and 3 michy yellow levers and an oldschool michy pressure gauge
whatever you do, dont buy a crappy anaconda or “fluid” one.
I have a small CO2, but the head on that is horrid.
or a tioga. I don’t reckon schwarzenegger would get past 60 psi with the POS I found myself with today.
what ever you do dont buy a shock pump. my friend discovered this is specifically for shocks and had no luck with his tubes. :stuck_out_tongue:
I got to 80 with the tioga pump i once bought. but from about 50 to 80 was a long struggle and my arms felt it.
tioga or something? just stuff in the back pack.
