ok, another BB question from me
wanting to grab a phil BB for my new build. the cranks i’m going to be using are supposed to be used with a BB with a 109 spindle. but phil’s come 108 or a 110.5. which is my best option here?
thanks in advance.
108 is better because you can space it out a millimeter if you need to, but you can’t chop a mill off…
tops, thanks!
How would you do this with a Phil?
tick.tick.tick. have you considered White Industries? Just as good and the correct length.
hadn’t even thought of white industries. i’ll look into it, thanks!
Phil BBs have some adjustability in the chainline. 108mm will do the job.
