I have some wheels with some old school Kinlin rims, if I can find some 36H hubs I was thinking of putting together a set of wheels with those. They’re heavy as balls but I think they’ll be pretty bombproof.
28mm Thickslicks, FSA Gossamer crankset, Ultegra bottom bracket, I made my own quill stem adapter, have a short Ritchey stem and some 580mm wide rizorz. Brooks saddle maybe, need to track down a seatpost yet (25.6mm dia)
Spent some time hand filing last night. Put a bit of a chamfer on all the edges and cleaned up a bit. Axle clearance was a bit tight too, got that sorted.
Had a couple of misses with the primer. Missed a spot to start with then got a dirty big run when I went to patch that up. Then sanding out the run went back to the bare metal. To smooth the primer off I rubbed it back with a scouring pad, that seemed to work well because I could get right into the corners/welds without fear of taking off too much of the primer like wet & dry seems to do.
Looking good now though. Too good for a spray bomb paint job? I dunno, I always seem to second guess myself part way through a project…
Headtube and BB didn’t get painted, but I did put some on the steerer as it was all bare metal. I’ll probably have to take the paint back a bit with wet & dry where the crown race sits before that gets assembled.
