I thought I should put together something fixed gear before I get banned
A steel frame of unknown origin is the victim. It’s not exactly lightweight so not really anything special, was a roady before someone cut off the derailleur hanger. Which was pointless because it has vertical dropouts. OK, had vertical dropouts.
Where it’s bolted on the outside was just a bit of a joke (google roadtopista).
I had it bolted there so i could scribe the cut line on the existing dropout. With the new pieces welded in place the spacing is 135mm. I’m not sure if this frame has been cold set before but it will pull it into 120mm, whether it likes it or not.
