At last, a sweet high flange modern road hub, looks real nice.
The RHUB is a high flange hub for use with ten speed cassettes.
We’ve partnered with Industry Nine to create a cassette hub that marries our hub shell, axle, and bearing adjustment system with their premium Mountain Freehub.
The drive mechanism has two sets of three pawls on a sixty tooth ratchet that provides 120 points of engagement at just 3°. What this translates to is a freehub that responds nearly instantaneously to rider input.
The splined freehub body is compatible with 10 speed cassettes from Shimano and SRAM. The axle can be adjusted to 130mm or 135mm in length.
The large solid flanges provide a solid base for wheel builds with their large diameter and nearly symmetrical spacing.
An oversized aluminum quick-release axle supports the hub on three sealed bearings, along with a massive 40mm bearing supporting the freehub.
The RHUB features our simple bearing adjuster ring for hassle-free maintenance. The freehub is simple to disassemble for service, and can be converted to run on just three pawls instead of six for lower drag and less noise (but with a 6° engagement).
