Unless you’re Jobe Dajka, there is no need for straps as modern pedals are really secure anyway. For instance, I use the 2007 Ultegra pedals which now incorporate a wider platform, ala Dura Ace. They’re damn sweet, and not overly large so pedal-strike shouldn’t be an issue. I have always used Shimano, so I have no idea about the other manufacturers.
Having said that, if price was no object, you’d want <a href=“http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ih=020&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=300120436938&rd=1&rd=1”>These</a>
I’m using Speedplays and love em! Mine are the older style ‘X’ series which are probably not the best since they float all over the place. Also, when the springs in the cleat wear flat (like mine) they rock a bit side to side, but I’m no Jobie - they work great on the track
The newer ‘zero’ ones have a much better c-clip that does not appear to wear quite like the X series do. A few guys on Tuesday at DISC use them and they all swear by them… Dunno if that helps at all.
Try the Keywins…they come with a locking pin option for when you are on the track…then press the pin and it disengages for float and unclipping on the road.
While on the topic, are there regulations about which pedals you can run at DISC? Currently I have MKS’s with double straps thought could also change back to SPD’s if needed?
