Anyone else riding Phillwood hubs on an NJS track bike? I found the cone shaped washer/bolts don’t fit the very thin drop outs, so have left the wheel in using only the allan key bolt holding it in, worried there might be way to much pressure running through the tiny bolts.
Not the spacing sorry, the dropouts are Suntour 8mm, may be a case of getting some washers to place between the frame and the allen key bolts for more surface area.
Im no PW expert but the shafts might be too big for the dropouts. 8 mm is too small for standard 120mm hubs which come with 10mm rear shafts. could be completely wrong though
The problem is the axle diameter. Most track axles are 9mm front/10mm back, or 9.5mm front and back. The exception is an early NJS setup: 8mm front and back. This frame has been built for those axles.
I’ve always wondered why Suntour dropouts are stamped “Suntour 10mm” - now I know - it’s to distinguish them from the rare 8mm version.
If your hubs were any other type, your axles wouldn’t fit at all, so you’re lucky you’ve got Phils. I gather the allen bolt is around 7-8mm diameter.
You could fix the problem by leaving out the sleeve washer, (like the first photo) and adding a flat washer to spread the contact area… but then you’re basically riding with a fragile 8mm axle. If this was for the track, I think you’d be fine, but are you the Blaine I know? Is this your work bike? I wouldn’t use 8mm axles on the street - I did once, and let Lewis do some bunny hops on it - result was a bent front axle.
I guess if you want to use that frame on the street, you probably find someone to machine the dropout slots out to a 10mm width. I think there’s enough metal there to allow that. Is the front hub the same though?
yeah i would slot the drop out so that the phil washer will fit in there. the washer is stepped, so there is a wider diameter bit that locates the washer into the drop out
there’s heaps of meat on that dropout to take 2mm out of it
Dubrat’s image has the bolts, I’ve flipped them inside out because the insert section of the bolt is 10mm, and the drop out only allows for 8mm. Not the best solution…just hope nothing pops out while riding.
