I have made another commuter/CX. 1 x 8 shimergo (all shimano rear/record 10 shifter). I want to remove the shifter paddle and thumb button from L/H record shifter. Has anyone done it?
Anyone got a link to an exploded drawing? I’m concerned about rattles and/or bits of shift drum falling out in the interim should i wish to reinstsate the shift at some point in the future.
Just in case normal crabon roadies come back into fashion?
Google… there’s exploded drawings around and youtube/vimeo etc probably has instructional videos on doing this. I’ve seen some on how to solve tech/installation problems.
I’m such a shit mechanic, I have to look up most stuff before I attempt it.
The one on campyonly.com is aparently the Campagnolo factory one.
Just doesn’t give me a semi like most exploded diagrams…
Guess i’m really after answer to what to do about shifter bits left.
My LBS has a set of record crabon brake only levers n hoods…for more than I’ve spent on whole bike!
Went and checked the levers then made a picture.
Very similar shape, blades are slightly different in curves.
And the blades on the Tektros are bright ano not grey.
Texture of hoods is different.
They do feel similar, I had the R200s on the Kona and have the same shape Centaur
shifters on my roadie, with same shaped bars. Feels pretty much the same.
I decided to just take out the whole gizzards after all. I have done g springs before and thought this best.
I made a little plug to fill the hole.
First ride tonight…Feelsgoodman.
