Rear Rack for Canti screw holes - Voodoo Dambala
I’ve reached the point where my current commuting combo of Topeak Beam Rack and Drybag no longer meet my needs. The drybag is losing the tightness in its retention clip and the bag is sliding off the back of the rack while I’m riding along. Happened three times in two days this week, including smashing my Cygolite Hotshot 2 the first time.
The Voodoo Dambala frame has screw in mounting points for cantis and a screw in hole for a rack/fender down at the dropout (11 o’clock position above top bolt in sliding dropout in the pic). There’s none of the usual rack mounts up on the seat stays.
Failing in my googlefu to find a rear rack that will mount onto those canti screw in holes.
Does anyone have a suggestion on a rack to suit my current situation before I resort to a Surly seat clamp with rack mounts?
Cycling Bike Aluminum Alloy Bicycle Front Rack Panniers BAG Bracket Carrier DH | eBay
Not a rear rack, thanks though.
I’ve got a Voodoo Wanga with the same setup. I looked into how I could fit a Tubus Logo onto the same mounts, similar to this:
The problem is that the position of those canti bolts aren’t sufficiently horizontally apart from the axle ones, so the rack wouldn’t be as strong in fore/aft movement. It’d also involve fabricating a bracket to match the bolts to the rack.
So I did what it looks like you might do, and bought a Surly seat post clamp. It’s heaps good :slight_smile:
You could also just get some plastic coated steel saddle clips and attach them to any point on the stays. Like these guys:
^ that has pivoting lower mounts, so should bolt up OK. Won’t take panniers etc tho.
But what I’d do is buy a good rack (tubus) and then get a set of the stay clamps (or a salsa/generic seat clamp with mounts) like these:
Tubus Clamp Set - Rack Eyes Seat Stay Mounting - £8.99
Double beaten, but the tubus clamps really are great
Yup.
