INITIAL REVIEW
So after a couple of rides (strava says 168kms), I’ve got a few general comments on the Rove ST.
Worries about the cable discs are pretty much gone. I would upgrade to hydros for only two reasons at the moment: less adjustment/fiddling, and easier heavy braking (less hand strength to engage brakes fully). I tend to use one finger when on my mtb with hydros, but with these brakes I tend to find two is the minimum from the hoods. This could also be because of less leverage in that position as well though. Brakes were really shit until bedded in [don’t judge brakes before this step]. Also, the shift paddle tends to get stuck to the bars if you pull the RHS lever all the way in. So need to adjust the brakes carefully. This means your range of motion is slightly less than if you were running a single speed setup, or gevenalle shifters / barend etc.
Frame feels really solid. Not a noodley old school steel frame or something with a lot of flex. Steel fork is ok I guess. Nothing to compare it to. But assume maybe crabon might have less road noise?
Sizing - I was tossing up between 54 and 56 based on geometry charts (stack, reach, ST, HT etc). Nervous about it because I had found a great deal on the bike, but hadn’t been able to sit on it. Kona’s size chart said I should be (based on 183cm tall) on 59-61cm for their Road/Rove frames. This seemed way off, and geo charts showed very different numbers based on my current bikes. Ultimately I went with the dealer’s recommendation of a 56 (56 ST, 58 HT), and I’ve found it nicely proportioned.
Clement MSO tyres seem good. Haven’t set them up tubeless yet. Have been running them at around 55-60psi. Was thinking about getting some wide slicks (most of my commute is road, with optional fire trails), but might also just tubelessify the MSO’s and ride them until they die. Definitely not as fast as my 25c Contis, but more comfortable over shitty cycle paths, and can ride down a steep fire trail without feeling like I’ll go OTB or washout the front at the first sign of gravel.
1x Rival is really nice, and a sweet improvement from the old Sora I was on. Double-tap took all of 2 mis-shifts to be second nature. Low gear is enough for most climbs, with only steep rocky fire road being walked. Jumps between cogs can mean you don’t find the ‘perfect’ cadence if on a long straight, but I don’t care too much about this, and have used it as an opportunity to shift up and spin a bit more than I normally would. With the single shifter, I’m also less inclined to just stomp up a rise in the big ring purely because I don’t want to cross chain too much or shift down the front. Sit and spin has become more efficient.
Commute details – I transferred my alloy rack over from the trek and have been using the same DHB pannier bag No butt-rocket yet. Chucked some gaffer tape on the frame where the bag sits to prevent rub. There is a bit more heel clearance to the bag with this frame, so that’s a good thing. I also electrical taped some frame rub spots for cables, and have added my front and rear lights. When running low pressure I get a bit of rear end wag (from the pannier bag I think) if I’m throwing the bike around. But overall has been really solid as a commuter.
That’s enough of an essay for now. If anyone has specific questions because you’re looking at one of these, just let me know.
