Hi,
I’m wondering if anybody may know if these brake levers can be used as a solo brake lever? They’re a Cyclocross Cross Brake Lever intended for use as a second brake lever that the cable can ‘run-thru’.
I assume that they can also be setup for use as a solo brake lever for a fixie. I like the look of 'em
Just wanted to check before ordering from the UK.
Thanks
Just make sure you workout what bars you are running them with. I swaped bars at the end of a build and the cross levers that would have fitted the broad 31.8 clamp section on the original bars would not fit the new bars with a narrow 31.8 clamp section and I am having to swap to a lever to fit a 26.0 a bar (which I think should work) even though the new bars are 31.8 if this makes sense. Get the vernier calipers out and work out where you want the brake levers.
