If the brake has enough spring tension it should keep the cable end (bottom one) seated. IMHO get different levers. They’re just a bit shit really. BL-R550/R780 are cheap and great (there are linear pull / convertible versions.)
what brakes do you have? those levers come in linear and caliper pull.
@AL9000 - I’ve got caliper brakes. Fair enough, will definitely look at better levers if these are just a shit design. For now, would love to get rolling with them though.
incorrecty cabley. you want either A or B out of Diddys picture. the round end cables fit into MTB levers with slots like this:
(this is a terrible photo, but basically the slot the flat part in from a cutout underneath the lever, TLDR you need the bullet shaped brake cable ends)
