I took my Alex G6000/formula hubs to the LBS a few days ago and they called up today saying there wasnt enough thread on the hub to get the sprocket and lockring on.
They said i can either go freewheeled or i will have to buy a new rear hub if i want to go fixed.
has anyone eles had this problem with these wheels?
Yeah normal formula hubs, I’m a bit pissed off that for the price they said they would charge me for the new rear hub costs almost as much as the wheelset it’s self.
I had G6000’s and had a cog/lockring on there just fine, even a Sugino fixie/track system for some time as well and that was fine. get another sprocket/go to another LBS.
it can depending on what the parts are, but since your wheelset was cheap as chips i would just get a cog off ebay and put it on yourself its not rocket science. unless the hub thread is damaged there will be enough thread to fit a cog and lockring on. i know because i bought that wheelset (and why would they sell thousands of hubs without sufficient thread).
have you tried screwing it on yourself? do that and see if it fits. i think i have a cheapie on mine and if i remember correctly a formula lockring. as long as you can fit a lockring on without a gap between the cog and lockring you should be fine. remember to rotafix the cog so its on tight before you put the lockring on.
Get a decent cog, a decent lock ring and buy a tool (for the price of what your shop will charge you).
Then you can do it yourself… or get someone here to show you for the first time.
thanks guys, i went again today and they said that that wouldnt work and that the thread is two short even if i try different cogs.
so it will never work???
Two people in this thread, one of them being me, have said that we have run cogs and lockrings on our Alex G6000 rims with no problem. There would be 3 or 4 other people i know running the same wheelset with no problems.
HOW HARD IS THAT TO UNDERSTAND?
Go to another damn shop, buy a cog and lockring there, should get change from 30, and if they are nice enough they’ll fit it too.
