My Corsas are significantly wearing faster on on the rear then they do on the front. With my old tires I didnt really notice that before but with these ones I do. Do you:
-change front to rear
-change both tires
-change just the rear
-ride as is until the rear tire is completely worn
Easy. With tan walls and brakes when the rear need replacing I buy 2 new tires and keep the old front. When the second set’s rear wears out I replace it with the first set’s front. Keeps the ‘patina’ as close to even as you can.
