hey wondering if you can fit a 700 x32cc tyre on deep v’s with 700 x 23 tubes? looked around on the net, found some info but just wanted to make sure, a person i know bought the wrong tyres. thanks.
ps: will tire pressure be an issue?
Assuming you have a good quality tube you should have no problem.
Think again! There’s a reason why they make different size tubes, yeh? You can get away with a 23 tube in a 28, but not so much in a 32. The rubber stretches out and gets to thin, and bang.
Just buy some new tubes.
I’ve used 23 tubes on 45 tyres with no problem.
I wouldn’t bother…
The real question should be can you fit 32c in your frame?
