Bit of a simple question about v-brake pads- why the hell are they so damn thin?? I’ve already worn out the front pair. If you look at the thickness of the pad on the cartridge type, it’s significantly thinner than a regular canti brake.
So question is can you get thicker type pads, or is it more a function of the v-brake design?
eagle claw / supra’s work for me on my tourer.
don’t seem to wear super fast or anything
the koolstop cross compound pads as per the left side of pic also seem to work OK on the pomp.
i was going to run them until they wore out but they haven’t yet (i do have the pad holders in the right way round)
I had a few problems with chunkier pads with 32+ as they took a looooooong time to align and even then they wouldn’t sit on the rim properly, they would have to sit a bit lower and brake on the actual rim or else in their resting position they would make contact with the tire. I would recommend going thinner cartridge and replacing as needed.
