I have a 8 speed sachs maillard freewheel which I want to remove but I am unsure which tool is the right one.
I think I need the equivalent of a parktool FR-1 (http://www.parktool.com/product/freewheel-remover-fr-1)?
Can anyone share some knowledge?
Here is a pic:
Just want to make sure before I buy the wrong tool.
If your just gonna remove it once why not take it to a shop? - it’ll be cheaper than the tool and if they don’t have it you won’t pay - or buy the wrong one…
Although I just begrudgingly removed one of those with an angle grinder. It was seized onto the hub and no amount of Wd40 etc and force/leverage could budge it.
I have a 18t freewheel with 8 splines/slots instead of 4. I’m looking at removing and swapping to a smaller freewheel.
The question is, will a 4 prong removal tool work?
The freewheel is a cheapie which came with the wheels, only info I can find is below. LONG YIH INDUSTRY COMPANY
If you have a look below you’ll notice the spline ridges are quite thin (unlike earlier Maillard freewheels). + most LBS’s should have the the Shimano tool.
