CraigC haz White Industries Eno cranks that haz a lockring (the thing that holds the chain-ring on) that slips/loosens and I am having to tighten the ‘little mongrel’ up all the time. Would putting the weakest of the Locktites on the lockring cause any problems down the track. I have sometimes found with locktitie that once it’s on, you can’t get the fucker off. The cranks and the lock-ring are both made of alloy, also it’s a White industries ‘only’ lock-ring from what i have been told.
http://whiteind.com/Tech_Info/INSTRUCTIONS/cranks.htm
Dunno if this helps? Maybe email them, they may be able to suggest something.
PS The guys down at the ‘Club’ said to say hi
Something, somewhere on that interface must be worn. Otherwise there shouldn’t be any reason why the lockring constantly loosens. Check and replace if nec. Otherwise loctite is fine.
Des
609 baby.
