Really not sure what to call this one
My first frame work fixed gear which I grabbed while living in Berlin was feeling neglected so I did something a bit different with it. Probably need to file this under ‘sounded like a good idea at the time’ but it’s interesting none the less. Basically it’s a generic frame but the wheel set has a 3-Speed Sturmey Archer hub in the back and a drum brake wheel up front (yep, this bike ain’t lite). The basic idea was to build something for riding on things like rail trails with lots of gravel and moderate grade. Yet to use it for that of course. Here are the specs:
Frame and Forks: Generic Steel White 55cm (C-C)
Front and Rear Rims: Velocity B43 700C Silver
Rear Hub: Sturmey Archer S3X Silver 3 Speed Fixed Gear
Front Hub: Sturmey Archer X-FD With Integrated Drum Brake
Tyres: Schwalbe Marathon Plus 700x32C
Chain: Izumi ECHO Track Chain
Cranks: Miche Primato Advanced Track Cranks 165mm
Chain Ring: Fyxomatosis 48t in Silver
Pedals: Some Crap Just for Photos
Saddle: Selle San Marco Laser in Black
Seat Post: Nitto SP72 Jaguar (NJS) 27mm
Handlebars: Nitto RB-021 Silver
Stem: Velo Orange
Brake Lever: Paul Component Reverse Bar End in Silver
My biggest complaint about the S3X hub is that it isn’t zero-lash, presumably just not possible but it basically means it feels like you are riding with a loose chain since there is a bit of play. Despite being heavy though the drum brake on the front wheel works really well. Here’s what this thing looks like:
I may have to sell it since I just don’t ride it enough. It certainly is interesting to ride though. Here are some more pics:
Bit of a MacGyver effort in that last photo, the stock clamp for the drum brake arm didn’t fit my fork, so had to go with a Bunnings solution.
