Bottom Bracket for Truvativ Touro?
I think mine has crapped itself…lots of grindiness…
Can anyone recommend a good replacement or does it have to be the same as the original?
Thanks
this might help
http://files.dahon.com/support/manuals/2009/components/truvativ_5_arm_crankset.pdf
they are a Truvativ Touro Track crank
It has to be the same type of bottom bracket but not the same brand.
Is it powerspline or square taper?
power spline
Sorry, never used power spline… isn’t that only Truvativ?
^ I don’t know that’s why I asked here
Why don’t you just pull your cranks off and give everything a clean first.
That might get rid of the grindiness.
Ok…but it’s a sealed BB so will that make a difference?
The BB has seen about 400km only I’d say
Yeah, that’s my understanding.
There could just be crap between the cranks/BB and frame. Hit it with the hose or a gurney if you want.
With so few Km’s I don’t think the BB should be stuffed.
+1
But I’d stay away from the hose (what’s a gurney? if it’s a high pressure hose, even worse!) and just pull everything apart and clean, regrease
