I’ve finally gotten around to using some of the belts I bought a while back and wrote up a brief description of how I converted my pub fixie to belt drive: www.kingsingleparts.com
I’ve got a few more to come when I can find the time and would love it if anyone can point me at some solid foam 700c tires.
so let me get this straight, there’s no join in the belt? so you have to build an entire frame/rear triangle around a chain that you then cant replace without taking the frame apart again?? yep, that’s some intelligent design right thurr…
Really??? I’ve used and worked on plenty of pieces of machinery running belts ,flat/vee/poly-vee, majority working at fairly low revs similar to cadence range, and the belts always wear, and inevitably cease to operate properly or snap… Can’t see these ^ being any different, and outlasting the frame?
The break in this one was done professionally (except the paint, that was me and I’m not entirely happy with how it turned out).
This is it before it was painted;
That’s a custom break made from stainless steel.
A whole heap less dodgy than my screwed attempt before. Having ran with the rats for a while in canberra I’m well used to having a little chop’n’weld on a frame but wouldn’t trust myself with one of my better bikes.
