[i]Post your CX pr0n pics here, whether they be CX, SSCX, CX parts, mud porn… You get the idea.
No “chick on bikes” trash either, just nice bikes or parts you’ve come across on teh internetz. Other stuff will be modded out.
In order to keep this thread of a somewhat high standard, no posts without a picture. So if you want to comment, make sure you have a worthy image to contribute at the same time. If they’re not your bikes or photos links to the original source are highly encouraged.[/i]
[i]And don’t quote images.
[/i]Moderation will be applied with a mud encrusted carbon fist.
Azz: Loose definition is that CX = drop bars, 700C wheels. To be stricter no discs until Sept 2010, no tyres wider than 35mm after Sept 2010. And as such Alvern’s doesn’t make the cut.
They’re sort of like road frames with space for fat tyres, and canti studs (or discs). But geometry is a bit different. Wheelbase is longer. BB is usually higher.
any amount of gears >0 is acceptable, singlespeed/fixed/single chainring/double chainring/whatever
frames look a lot like road frames but have extra clearance to support wider tyres, thus canti/v-brakes are often used
there are some common geo/frame differences but thats enough of a lesson for today
