Holy shit. I really should have not seen this website.
Also, don’t paint it! It’d look rad with original, worn it pain and new, shiny groupset.
got ya covered =)
Unless you are a dwarf I’d recommend going wider with your bars. General rule is/was that they should be at least as wide as your shoulders.
+1 on not repainting… new group+old frame=extra good.
Long way from Perth! Lol!
Nikcee, I have 42 and 44cm bars already and too wide for me. A bike fit pro would say they are fine, but I’m not comfortable. 40cm would be bang on maybe 39. But I have weird ideas when it comes to bike fit!
No repaint, new group,
Like nick said 39 bars are damn tiny,
If you feel like its lowering your upper body you could go a bit shorter stem
There is a movement gaining momentum…
#OccupyHillman
People in all corners of the world will unite in a global demonstration to claim our right to a weathered frame.
i have a solution… buy my super record compact 170 cranks… $300 and they are yours… about 2000kms on em, come wit CULT ceramic bearings, just order the rest of the gruppo as you need it… shiny bikes totally cater to that. min are ultra torque cranks which means… 10mm T handled allen key and a 10mm spanner or a shifter and your cranks are totally sorted… no pullers or special tool and 11speed rings work better than 10speed rings cause campag don’t develop the shifter ramps and pins on the 10speed stuff any more they just bang it out…
my SR cranks with the BB cups weigh 712g as well, not fucking around… ![]()
Lol’d!!!
So I’m going from buying a $370 group to $300 cranks?? HA HA #OccupyHLC’sWallet
$300 is a steal for the cranks… Only collecting dust right now…
Just pmed you some thing worth watching.
Ok, so here are some new pics. Check the wicked dent on the top tube
most people I talk to, even LBS, says it’s nasty but will be ok to ride! (Looks worse than it is).
I have decided on a direction for the build. All black urrythang.
-Black Veloce Group
-Black Headset/Quill/Seat Post (Would like to go top range everything - Tange Headset / Nitto Stem - but need 26mm clamp / Thompson Seatpost but have to check the budget
-40cm Black Ergo Drops w/ Black Tape
-Fizik Tundra Saddle - all black (prefer over the Arione)
Which means, I will need to do something about my Silver Aksiums and replace with a black wheelset. Would like something Deep profile, like 40mm, but again, sticking budget… Not too fussed on weight either as it’s a steel frame anyway… maybe lace up some H+Son SL42’s to something? will need campy freehub though… hmmmmmm decisions. Or might go something like Campag Khamsin to keep it full campy!
Also undecided on pedal set up. I want to move from SPD’s to road cleats, but still torn between Shimano and Look…
Anyway, Pics of Frame after i gave it a clean and hand polish. The paint is stuffed. Really bad to work with, it was drinking the polish basically lol. Feels lovely and smooth now, but I wouldnt want to get the buffer on it for instance.
-Wash
-Meguiars No. 2 Fine Cut
-Meguiars No. 9 Polish
-Meguiars No. 26 Carnauba Wax - 2 coats
The paint looks sweet IMO. However not sure I follow you about the dent, it would be better if it was in the downtube because thats in tension. The top tube is in compression.
You are right, I am wrong! Still, should be ok. As I said, took it down to a LBS whilst it was built/i was riding it and they said it’ll be fine. It is steel after all.
This is gonna look so rad all murdered out. Maybe the new HPlusSon Archetype in black could be an option? Not super deep but would still look pretty sweet I reckon.
If you don’t want to bust the budget, Khamsin’s are fine for starters. I have them teamed up with my black, Veloce gruppo and they both look fine and run great.
I hate you guys. Peer pressure sucks.
This is my favorite quote… 2 years on and it seems it was quite incorrect…
First Purchases. It begins.
Tange Headset:
Campagnolo Downtube Cable Stops:
Campagnolo Khamsin: $165 shipped from Ribble! Cheap!
And black/graphite Look Keo Max 2’s…
Haha it’s totally gona be PIMp!
