First off, yes I’ve searched here, and yes I’ve searched google but with no conclusive results.
I’m interested in a fuji track pro (yes, the one in the for sale section), the model with integrated seatpost. After trying it out with the seat clamp at the very (read very, very) top, it feels like it’s about perfect. Also measured up with the old heel on the pedal at the bottom of the stroke with a straight leg. However, I’m worried that a few weeks down the track (pun intended) I may for some reason need it higher. While this is not likely, I want to avoid it if possible.
Is there any way of effectively lengthening an integrated seatpost? I’m thinking perhaps a longer seat clamp, but I have not been able to find one online.
imho (which is internet slang for “i’m a ho”), one should steer clear of integrated seatposts. even the pros change their saddle height occasionally. ever seen a sunday in hell? and how often have you felt like you would’ve had more power, if it weren’t for that doggone seatpost flex?
In my experience with integrated posts (which is none at all) i would consider it a risk to be comfortable only at the higher setting. A change in cleats/shoes etc can require an adjustment, and being, like, 3mm off would be an outrageous turn of events.
There is a reason why a very well known frame builder changed their top of the line frames from ISP to removable seatposts a couple of years ago, and then tried to sell the ISP versions at rock bottom prices!!!
The Fuji pro is a great buy, they are good value, they are always discounted because anyone in the know would not but a track bike with an isp !! Just not a good idea on a bike- ever!!!
i have a fuji track pro, bought new, and had it cut by commuter to match the height of my previous track bike.
my back was hurting so i got a fit by Dr Dom. he actually raised the seat by 1cm (thankfully there’s a small amount of adjustment with the ISP/clamp and it wasn’t an issue). i was told to stretch and haven’t had any issues.
but if you’re at the absolute limit of what is available, i would be very cautious. measure everything on it and compare it to your current setup, or ask if you can borrow it to get a fit done, and will purchase if deemed suitable…
Perhaps so, but apparantely the main reason these frames were heavily discounted was because they stuffed up the chain stay and you could only fit on a 45t chainring.
