I’ve recently made the trasition from carbon 20 speed to Cro-mo fixed (All City Big Block) for my commuter and as a part of my build, I installed a sweet set of Sram Omniums (yes, 165 x 48t). I did a lot of reading before commiting and the general concensus was that the BB on these were pretty rubbish.
Turns out they are incredibly rubbish… 6 weeks and 1300ish kms later and it’s well on its way to being fried.
I had planned on changing it out anyway given the spectacular reviews, but I hoped it would be a fair bit later down the track so I hadn’t given replacement options much though.
So enter the collective destructive experience of FOA; What are some bulletproof (68mm) options for me?
shit man whats wrong with you? i normally get 5-10000km out of them, and thats only because they get a bit creaky and annoying.
but yes, they are quite shit, but for 30bucks delivered, what do you expect??
couple things of note though. i dont bother putting gease behind the dustcaps anymore as this just seems to attrack grit and makes them noisy. also try and make sure u get the newer style ones, think from 2010 onwards the design was a little better, looked nicer, and had less drag. these ones:
BUT… im also interested in a good possible replacements, one was suggested to me ages ago, but i cant remember
I was about to say the same thing, I have well over 5000km on my current gxp bb and it is still going strong. That includes winter commuting/all conditions not just fair weather riding.
You could trying using one of the Truvativ gxp bb from the mountain bike range rather than a standard road/track gxp bb. Apparently the seals on the mtb ones are much better at keeping the elements out.
Yeah, I’ve already commited to the external dicipline and aside from the BB I’m pretty happy with them, nice straight chainline, super stiff etc.
Do you think a million dollar Chris King would last proportionally to the cost? I’d hate to install one and then have it chop out in the same time frame…
Hey Red, do you manage to quieten them down by doing that? Mine have a distinct ‘click’ at the same point in the non-drive side revolution, and what feels like a slight grind (although this may be made mentally worse by the noise)
Its already had a fair bit of wet weather work, but probably not much more than anyone else around here…
^^ ive never worn them out enought that they “grind”… maybe it is all in your head
but yeah, pull them out, use a rag with a bit of petrol to clean the grease out then put the caps back on. i suspect you will find road grime and shit in there that will need to be removed. and moving forward, i clean mine out about every 2 weeks. more frequent if im riding in alot of rain or shit surfaces, and also clean the threads of both the frame and bb incase and grit has worked its way in there.
Thats what i’d heard, but my guns are pretty huge…
I might give them a thorough clean out tonight, just seems a little counter intuitive to be wiping grease out rather than cramming it in. But I agree entirely with grease being a grot magnet.
Is the CK service kind of like the speedplay service? As in you can do it without removing stuff from the bike? Not that Omnums are the most difficult thing to remove going around…
yeah do that. and realy the grease behind the dustcaps isnt that essential imo, it has nothing to do with the bearings themselves, and the way they are fasioned(at least the newer ones) there isnt really enough contact between surfaces to really need greese(not sure that makes sense, just have a look when u pull the out). it seams to be more of a “just incase” kinda thing to me. but anyways, plenty of k’s on mine no worries.
EDIT: and let us know how any others go that u try. i dont mind blowing through 30bucks worth of bb, but if i bought a nice ck or token or somthing that blew up just a quick, i would be pissed… be my guiny pig
Was going to say the same thing. My Omnoms are three years old now with the original BB on my track bike which is never ridden gently. I used to commute on it too so it’s seen some dirt/water.
Despite this problem of BB’s, I would still use them over many available track cranks. Let me know how you go, I may have to replace mine eventually?
