Following on from some of Prawza’s comments the other day, I had a look at the above regulations within WA.
Take a look http://www.austlii.edu.au/au/legis/wa/consol_reg/rtr2002290/index.html
Points of interest, in particular for fixed gear riders.
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 6
6 . Brakes
A bicycle must be capable of being braked by either or both of the following means —
(a) an effective foot brake operated by turning the pedals in the reverse direction;
(b) an effective hand operated brake fitted to the rear wheel having the operating handle fixed in a position providing for convenient operation.
Interpretation: It stipulates “effective foot brake by turning the pedals in the opposite direction”. Stopping motion on a fixed gear bike by use of your legs to create resistance or a countering force - is that effective foot braking (legally?)? Definitely grey.
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 7
7 . Bell
A bicycle must have a bell or other effective warning device fixed in a convenient position.
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 8
8 . Handle bar
The handle bar of a bicycle must extend not less than 200 mm nor more than 330 mm on each side of the centre of the bicycle and the height of the uppermost point of the handle bar must not exceed the height of the uppermost part of the seat by more than 300 mm.
Interpretation: This equates a legal chopdown size to a 400mm width bar. I personally have never really gone below - say - 450mm?
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 11
11 . Reflector
(1) A bicycle must have affixed at all times a reflector that will effectively reflect red light when illuminated by the headlight of a vehicle approaching from the rear and that reflector must —
(a) comply with the requirements specified in rule 102(1)(a) and (2) of the Vehicle Standards and have a reflective area of not less than the area of a circle of 38 mm diameter;
(b) be mounted on the rear part of the bicycle at a height that is not less than 330 mm nor more than 1 m; and
(c) be mounted vertically and facing to the rear in such a manner that the light reflected from the headlight of a vehicle approaching from the rear is clearly visible to the driver of that vehicle.
(2) The reflector required by subregulation (1) may be in the form of a reflecting lens fitted to the rear lamp.
(3) If a bicycle is being ridden between sunset and sunrise, it must have affixed, to each wheel, 2 yellow side reflectors complying with the requirements for reflectors in Australian Standard AS 1927-1998 ( Pedal Bicycles — Safety Requirements ) and Australian Standard AS 2142-1978 ( Specification for Reflectors for Pedal Bicycles ).
(4) If a bicycle is being ridden between sunset and sunrise, it must have affixed, to both sides of each pedal, yellow pedal reflectors complying with the requirements for reflectors in Australian Standard AS 2142-1978 ( Specification for Reflectors for Pedal Bicycles ).
(5) A bicycle must not have affixed a reflector capable of reflecting red light in the forward direction.
Interpretation: Go into any LBS these days. How many bikes do you see that ride off the shop floor without suitable reflectors? I dunno if Ive ever seen a bike priced in excess of $1000 with a reflector fitted?! K-Mart specials are all over the reflectors though!
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 12
12 . Lights
(1) If a bicycle is being ridden between sunset and sunrise —
(a) there must be attached to the bicycle a lighted front light showing an unbroken white light that is clearly visible at a distance of 200 m from the front of the bicycle; and
(b) there must be attached to the bicycle or its rider a lighted rear light showing —
(i) an unbroken red light; or
(ii) a red light that flashes regularly at the rate of not less than 60 per minute,
visible at a distance of 200 m from the rear of the bicycle.
(2) The vertical distance from the ground to the centre of each light referred to in subregulation (1) is to be at least 330 mm.
(3) In addition to the light required under subregulation (1)(a), a front light showing a white flashing light may be attached to a bicycle or its rider.
Interpretation: Enough said. Stands to reason.
ROAD TRAFFIC (BICYCLES) REGULATIONS 2002 - REG 15
15 . Offences
(1) A person must not ride a bicycle on a road unless it complies with these regulations.
Penalty: 4 PU.
(2) For the purposes of section 102 of the Act —
(a) the offence in subregulation (1) is prescribed; and
(b) the amount of the modified penalty for the offence if it is dealt with under that section is 1 PU.
(3) Despite subregulation (2), an alleged offender against subregulation (1) who is under 14 years of age is not to be dealt with by way of an infringement notice and modified penalty.
Interpretation: A penalty unit is $50.
Learn anything new???
