10,000km’s !!! Bravo !!
Pro tip: commuting is where the big k’s are at.
It will take me about 8 years of commuting two and from work each day to get to 10,000km
Since April last year for me…
Ok, so I’m running a shimergo setup on my Voodoo - 10-speed Ergo shifters to Campy 9-speed double front and Shimano MTB 8-speed rear. Also running V-brakes with travel agents. It’s sweet.
But, I’m now considering having a full MTB front I can swap out on occasion: front shocks, front disc, flat bar with MTB levers/shifters.
Can I now go back? The rear will be fine with 8-speed MTB shifters. And I could find a short-pull flat-bar lever for the rear brake so I don’t have to remove the travel agent each time. But what can I use to shift the front (it’s a current 9/10spd Veloce derailleur with a 9-speed Campy triple-turned-double-with-bashguard crankset)? Am I limited to having a bar-end shifter for the front?
Also, is there a simple clean way of being able to swap out my rigid forks and drop bars to shocks and a flat bar, with the associated change to shifters/levers, without having to use (and set up) a second set of cables for the rear brake and derailleurs? Could I use a cable-splittler a la S&S coupled travel bike?
Blakey what’s the answer!?
(I’m suspecting it is: “buy another bike”)
Report: failure. Took me some time to try this out cos #dadlyf and other things, but now I know that a Deore hub does not take a Campy Scirocco freehub body. Not a problem, I gave my Shimano hubs a good cleanup and reconciled myself with using those wheels, even though they’re heavy as.
Can’t say I’m surprised!
all of the ratios!!!
Cool. Ta.
Any chance an Ambrosio Campy freehub will go on to a Gipiemme Shimano wheel (10sp)?
No idea, sorta unrelated to the mismatched drivetrains that this thread is about. Compare the two (photos / IRL?) and see if the dims and interfaces are the same perhaps. Doesn’t sound as easy as campy:fulcrum.
But that reminds me to post this:
EQUAL PULLEY!
The red one just saves you having to run hubbub cabling, so… waste of money unless you want to use a 9sp shadow mech? And the gold one lets you run a 10sp shimano RD with 11sp campy levers and 11sp shimano cassette, but the stack of campy and shimano 11 are basically the same, so why not run the levers with a C11 RD and it’ll be fine on the shimano 11 drivetrain…
The fact that both 2015 and pre-2015 levers use the same pulley indicates that the cable pull is the same, but all the literature says they changed the pull (UK campy tech over at WW reckons they ran tests and they’re not compatible.). Which is real…
Well, I’ll have a mismatched drivetrain if I can’t swap it over ![]()
I have read the same Blakey,
Main difference is the geometry of the rear parallelogram mech, longer front mech cage and different shifters.
So what your saying is the internals run the same part numbers?
I’m sayin that the EA PULLEY people seem to think that their conversion piece works the same with pre 2015 or post.
So either they’re wrong, and one of them doesn’t work, or they’re right and the change in pull is within the tolerance of the floating upper pulley on the shimano mech.
Makes C11-S10 or C11-S9 shimergo tough if supply of pre 2015 levers dries up and the 2015 ones don’t play nice.
All of this ignores the front shifter, they don’t mod that, but 2015 on would probably work well with a 5800/6800/9000 FD as they both have longer arms.
