So most of you have probably switched off from this by now but I just spent a lot of time swimming through a lot of really whiney comments on the Rawland forums to retrieve info. This has all probably been covered in this thread already but here it is again all in one easy comment!
Essentially it is a road bike with low trail geometry and 55mm lightweight supple tyres, to offer very sure footed road bike handling on a wide range of surfaces. It can also carry a front load. I’m thinking mixed terrain randonneurs and endurance off road stuff.
Apparently the ‘Island in the pacific’ bad-taste-in-ya-mouth comment was a tongue in cheek reply to an earlier comment made by somebody else, asking about the origin of the tubing. So it was quoting somebody else’s offensive misstep. Still a poor move but whatever.
Will be available as frame/fork for $1200 in Reynolds or for around $725 in the same Taiwanese 4130 usually used by Rawland. Seems that the Rawland geeks are deciding which to go for, but as with everything they try to decide on it looks to be split 50/50 so I would guess that both will be made. Same super light fork will be used on both. Also available as a full build with Reynolds tubing for $4,500 which is what this deposit is for.
The disc brake thing - as Sean puts it it’s a bike ‘designed around peddling, not braking’. So basically, being a road bike and not a mountain bike, he’s envisaging that it will not really need the extra braking power of discs and the pros of being able to use an ultra lightweight fork outweigh the cons. I think the shock of non disc is amplified by the fact that it is a mountain bike standard wheel size, if it were 700c (and uh, 2012) there’d be fewer eyebrows raised. I’m skeptical on this one despite not being a huge disc fan, but I’m willing to put a bit of faith into Sean’s design and experience. And I don’t really mind cantis.
As for why a bike with such large supple tyres would need super light fork blades - It is so that the bike handles road surfaces, where a higher tyre pressure is required, just as well as it does off road surfaces.
It is 1" threadless, and it seems that the frame is probably going to be 132.5 spaced after all.
Also as for colour, each individual tube on the bike will be painted a completely different colour, sort of like that funky Volkswagen Golf in the 80s.
Nah just kidding. Only about the colour.
